mkirsch
Jan 31, 2017Nomad II
No, it does not make sense.
The breakaway switch is just a plastic pin between two spring-loaded metal contacts. There is no magnetic locking mechanism in any that I've ever seen.
Most likely, you got the pin seated properly/loosened with all your tugging, and it is just a coincidence.
If it bothers you, REPLACE IT. Breakaway switches are cheap and simple to replace.
The REAL problem is that you likely burned up your trailer brakes from leaving it engaged all night long.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
