- JanssExplorer IIThe driver said "I heard a funny noise and I put on my rear view camera and the car was gone."
I always drive with my rear view camera ON all the time. Do you? - JagtechExplorerLooks like those Chevy's are just crimped together. Glad no one was hurt.
- navegatorExplorerBase plates should be attached to at least some part of a frame, as in the engine supports or the front end steering stations, many tow packages are also installed by persons that do not follow the complete instructions and do not install all of the components, therefore creating situations that are beyond the owners control.
My two toads have base plates attached to frames welded and bolted, also have a brake away independent from the tow plate and cables that go to the frame.
I am glad no one was hurt, we can all learn a lesson from this check your tow package, and try to be safe for every ones sake.
My guess is that the base plate was not installed with all the components that the base plate originally had, and some components where missing, no manufacturer of base plates is going to open himself to that kind of liability.
navegator - traveylinExplorerRoot cause is failure of the unibody construction and secondary braking systems may have stopped the vehicle to the right side of the mv safely or may have stopped the vehicle to the left side of the mh into an oncoming car.
I would not tow a vehicle that did not have the base plate properly attached to the vehicle frame and back up safety cables also properly attached to the frame. I would not tow a unibody do to workhardening of the thin shell
pops - dodge_guyExplorer IIIn this case even with breakaway brakes, the system would've not operated after it pulled all the wires out. Unless it's a system that operates when the power goes away? This is why it is important to have redundant backups ie cables back to the frame.
- Dutch_12078Explorer III
Corkey05 wrote:
Dutch_12078 wrote:
Not a Roadmaster, .. looks like a Demco.
Wow! That was sure an unpleasant surprise I'm sure. I noticed in the shot of the front bumper/base plate, that the Roadmaster base plate apparently does not have the safety cables back to the frame that Blue Ox supplies with their base plates. I think that would have led to much less drama in this situation, since the car would not have completely broken away.
I stand corrected. Apparently Demco doesn't supply the supplemental safety cables either. - willaldExplorer II
WyoTraveler wrote:
All the RVers that have questions of why they need a braking system and why a break away cable now have a good photo of why. This is only the photo. Wait until the law suites start. Why no braking system? Why no brake away cable?
Law suits from who? The loose car here (fortunately) did not hit anyone or anything, except some bushes. The MH owner was very, very fortunate in that regard.
Oh, I guess the gas station might sue him, to make him pay for the bushes that his car tore up. :)
This incident definitely shows why a break-away system is extremely important. Its pretty clear here that such was either was not used or did not work properly.
HOWEVER, this incident does NOT make a case one way or the other for a supplemental braking system. The two (break-away vs supplemental brake) are not necessarily one and the same, you can get a simple break-away system without a supplemental brake (for example, the Ready-Stop device from ReadyBrake).
Its just really, really fortunate in this case, that the car went the way it did, and did not really hit anything or hurt anyone! 'Tis definitely one of every MH owner's worst nightmares, to look over at the reaar view monitor and not see a car back there.. - Everyone seems to be assuming that there was no brake system or breakaway cable. Well, if the portion of the car that the breakaway cable is attached to completely breaks off, a breakaway system does no good. It looks as though the whole front subframe of the car came loose, not just the baseplate. As for the talk of lawsuits, no one was hurt and some bushes got run over. Once the guys car is fixed, who is going to sue whom for what? Some flattened bushes?
- PopsieExplorer
WyoTraveler wrote:
That's why you need insurance - including an umbrella liability policy.
All the RVers that have questions of why they need a braking system and why a break away cable now have a good photo of why. This is only the photo. Wait until the law suites start. Why no braking system? Why no brake away cable? - WyoTravelerExplorerAll the RVers that have questions of why they need a braking system and why a break away cable now have a good photo of why. This is only the photo. Wait until the law suites start. Why no braking system? Why no brake away cable?
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 25, 2025
