ttsr4us's avatar
ttsr4us
Breakaway Switch Melted/Burnt
Airstream 2015 Flying Cloud 27FB
Well, Friday night our house washing machine broke down and today wanted to tow the trailer to our house to load up /clean tank/ for our trip starting next friday. Was hitching up and connected/pulled the cord on the breakaway switch and noticed the plastic covering was melting and burning.
Turned off the 12 volt but too late. Anyway, I pried the contacts apart stopped the process. Would like to know if a brake/12 volt electric/or just bad switch caused this issue.
Any ideas on how to proceed? I'm talking to Airstream tomorrow.
:M:E
  • Yep..3A draw per brake magnet.........minus resistance thru connectors/corrosion
    Per Federal Law...suppose to provide full battery voltage for 15 mins
    Get new switch....check wire/connections/insulation for any damage
    And anyone that pulls pin out to use as a parking brake doesn't understand trailer electric brakes.
    Magnets will get energized due to full battery voltage BUT brake shoes do not engage unless trailer is moving. Sitting parked .magnet just gets HOT and battery has unnecessary draw
  • RoyB's avatar
    RoyB
    Explorer II
    The only way these contacts get closed in when you pull the KEY out.
    Like said above they are NOT designed to be left in this mode very long.
    Each BRAKE MAGNET will draw 3 AMPS when 12VDC is applied...
    If you have two axles then that is around 12AMPS of DC CURRENT for four wheel electric brakes.
    ETRAILER.COM should a good replacement switch assembly for you...
    I have heard on here of some users like to pull the KEY to use as a brake to hold the trailer in place. This really isn't a good idea as you can see what happens to the contacts and the BRAKE MAGNETS can also melt down which is probably on the expensive side.
    Something like this google photo
    Roy Ken
  • Brake magnets draw a lot of amps. The brake away switch is designed to close and lock the brakes up in the event of a brake away.
    They are not designed to be closed for a long period of time because of the amp draw.
    It sounds to me like the switch was closed for a long period of time and went past it's duty cycle.
Looking for advice before your next adventure? Look no further.25,169 PostsLatest Activity: Oct 11, 2025
