Larry-D's avatar
Larry-D
Explorer II
Nov 26, 2017
Broken Anderson Leveler
I've seen a lot of good things said about Anderson Levelers here and after a couple of years I bought a pair. 1st time out using only one on a single axle Rpod travel trailer it worked great. 2nd time out using a pair on a twin axle 28' travel trailer one of them broke. The one that broke was on the back axle and as it was coming down off the leveler it broke in half, at the same point where I have seen photographs of others breaking.
The temperature was approximately 55 degrees so it wasn't a freezing/brittle issue. It did not get caught on anything. It was rotating upward as the trailer was pulling forward and simply broke. The trailer certainly wasn't overloaded and the other leveler did fine. It looks to me that too much material is removed, or not injected in the manufacturing process since from other's photographs the break is in the same location.
Just wondering if others have had the same issue. I've sent a "question" to Anderson. They have a one-year warranty and these were purchased two months ago. Couldn't file a "warranty claim" online since our address of 37 years was "invalid". Got to love modern technology.
  • I've been using my levelers for 3 years now, mostly on hard dirt. I've had no trouble at all.
  • I use a strip of rubber matting under them when I think they'll need it. With my narrow tire spread I trimmed them down about 1 1/2". After using wood blocks for years I like then levelers although not perfect. I do carry a few cut offs of composit decking for the times the levelers down't have enough lift. At those times I put the rubber between the blocks and the levelers.
  • I have broken two - in both cases it was a larger (think lemon-size) rock buried in softer soil underneath the leveler that caused uneven distribution of the weight and broke the leveler. Andersen replaced both by two-day FedEx and I now check for rocks and uneven ground. If in doubt, I carry 12" x 12" squares of exterior plywood in 1/2" and 1/4" thicknesses and will put one of these under the leveler. We love them and have had no further problems using them with our 13,400 lb. (per scales) fifth wheel. (Tip: we also have a LevelMatePRO that links to the phone so I can see the how level the trailer is without getting out of the truck.)
    Rob
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
