BurbMan
Mar 09, 2021Explorer III
corvettekent wrote:
Move some weight forward in the trailer and add a second sway bar to the hitch.
OP is already at 16% tongue weight, a few more lbs isn't going to do much.
We towed with a Hensley Arrow for 20+ years, set and forget, never worry about the roads or the weather. If you stay with a traditional WD hitch like you have, the secret is to dial in the adjustment down to a gnat's behind. Measure front and rear of truck and trailer to be sure rig is level, be careful not to load too much behind the trailer axles. Rear kitchen models are tough because a lot of the weight winds up in the kitchen (pots/pans are heavier than t-shirts).
Find out where your fresh water tank is...if forward of the axles, you will do better traveling with full water, if behind the axles, tow with it empty.
If you towed all day in a 20-mph crosswind, the set up must be decent, now you just need to tweak it by trial/error to optimize. That, or fork over the cash for the Hensley or ProPride.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
