Mickeyfan0805's avatar
Aug 17, 2020
Bullseye dent in fiberglass rv
While washing our rig yesterday, I discovered a small dent in the fiberglass. The center of the dent is quite small, with concentric rings, like that of a 'bullseye' formation, extending out to about the size of a nickel. If it were up front or on the side I'd expect a small stone. Being on the rear, I'm not sure what happened. It honestly looks as though it was shot with a BB-gun.
It is not especially apparent, but I'm a bit concerned about water intrusion leading to delamination. Anything I can do to try to repair, or at least secure, this dent so that it doesn't cause increased damage?
  • You should look at how your wall is built, calling most of these smooth side trailers “fiberglass” is not accurate, most are very thin plywood with a paper thin coating that resembles fiberglass. Check a cutout where there may be an edge exposed. I mention this because you are making more of a wood repair rather than a repair like one would do on a boat. The product mentioned above shows broken wood, so it might be OK, just do your homework before proceeding.
  • garyhaupt wrote:
    Take a look at this product. I have a tube for a repair that I have yet to do. Called Magic Easy..from Australia..I bought mine in eastern Canada. The address I have included is your US connection.
    https://www.ab-marine.com/magicezy/
    Gary Haupt
    Amazon $24.99 ships free.
  • Take a look at this product. I have a tube for a repair that I have yet to do. Called Magic Easy..from Australia..I bought mine in eastern Canada. The address I have included is your US connection.
    Gary Haupt
  • "buy a spray can of clear coat and put on several layers and call it good"
    Very good suggestion.
  • It probably WAS shot with a BB gun. Is the fiberglass cracked? I'd probably go to an automotive store and buy a spray can of clear coat and put on several layers and call it good. Another option is to fill it with bondo, sand it smooth, prime it, paint it, and cover it with graphics. Unless you're good at fiberglass repair or want to spend a lot of money to have it repaired those are the options I can think of.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
