jon16's avatar
jon16
Bumper pull vs. 5th wheel
Looking for some insight. Considering buying a smaller 5th wheel or travel trailer. I have pulled many trailers, but never a 5th wheel. I pull a dump trailer quite often, and when fully loaded, weighs 12k. I obviously know what its like to pull that loaded, but how would a 10k-11k 5th wheel 'feel' and compare to the bumper pull?
  • Never pulled a fifth, but using a Hensley Arrow hitch has made towing a very pleasant experience.
    No wiggle or sway, at all.
    There's another company that makes 'pivot point projection' hitches, now; Pro-Pride. Have heard very good things about that hitch as well.
  • I pull a 10k dump trailer as well as my 5th wheel. The Fifth wheel is easier to hook up and my truck rides better with the weight over the axle not behind it. All though my truck is heavy duty enough that neither is much of a challenge.
    I greatly prefer the 5th wheel. Some say you can set up a travel trailer to pull as well as a 5th wheel. But you don't have to do anything to a 5th wheel to make it a pleasant experience. But then you do lose space in your truck bed and some people don't like the steps. There are pros and cons to both. I notice you did say a smaller rig. In that case I maybe would lean to a travel trailer. It will be less expensive and if your truck has a heavy enough receiver on it you will save the cost of a 5th wheel hitch. All kinds of things to consider. If going to a large rig my opinion is a 5th wheel wins hands down.
  • For one, you'll feel a LOT more wind resistance with a fifth wheel than with a dump trailer. Under most circumstances, this will have a big effect on your fuel mileage. Other than that, I find that my fifth wheel feels more stable on the highway than my travel trailer did - and at 2.5 times the weight and 11 feet longer. Starts and stops take longer, but that's to be expected.
