lawnspecialties wrote:
Not to start a fight at all. I don't care what people camp in.
But I've had both. From a 30' TT to a 33' TT to a 45' 5er and back to a 33' TT. If you have sway or other similar issues with your TT, you don't have a decent WD hitch or you don't have it set up correct.
Or you are towing to much trailer for your TV.
Reading through the above posts and I just don't have all the sway, wiggle and what not people talk about towing a TT and I have towed 30 or 40 different trailers with probably 200 different trucks over the last 20 years. Some of the 32 to 40 foot TT I have towed over 1000 miles at a time with nothing more then the correct ball and no weight distribution hitch or sway bars. Not to mention I am one of the hated tow over 65 guys on the forum. Common factor is all the pickups I towed with were 3/4 ton or better with 10 ply tires aired up to max pressure.
If your tow vehicle can't handle the trailer with just a ball all the add on towing aids are just a band aid covering the true problem.
