B92F's avatar
B92F
B&w Turnover Ball Hitch Question - Update in OP
We just purchased a 2015 Ford F250 that has the B&W turnover ball already installed. We were using a Husky 16K hitch in our former truck. Looking on line I can find a 20K hitch, but that seems to be a bit of overkill for our trailer. Is there a 16K or an 18K B&W hitch that will work with the turnover ball that I'm just not finding?
Update~
Went with the B&W 20K Companion Slider.The prior owner had left the gooseneck ball in the down position, and I didn't give it much thought until it came time to get ready to install a new hitch. It was rusted in pretty good, and took about 10 minutes and lots of penetrating oil to get it out.
Installed the hitch ourselves and it was really easy. I got lucky on setting the height of the arms. I picked the middle position (18") and 1" behind the kingpin post as the initial setup and hitched up to the truck. Trailer settled in with less than an inch nose high, over 6" clearance between the truck and the trailer, and the clearance between the tire and wheel well is around 18" on the rear and 19" on the front.
Haven't had a chance to take it on the road yet as I want to put new tires on before our next trip, hopefully in the next few weeks.
  • Thanks. I'm not opposed to the 20K, but was hoping that there might be something costing less. At this point in time I don't anticipate needing a 20K but who knows, I might in the future. :)
  • No the B&W 20K Companion is their only hitch to fit the B&W turnover ball. You may be able to find an adapter with rails to go over the ball, that will work with most regular hitches.
    I think available at etrailer.
    Jerry
