otrfun's avatar
otrfun
Explorer II
Aug 10, 2017
CA License & Registration Req for 3500 SRW with 11.7k GVWR?
Can a resident of CA driving a 3500 SRW with a 11.7k GVWR legally tow (for recreational, non-commercial reasons) a bumper-pull RV trailer with a GVWR less than 10k or a 5th wheel RV with a GVWR less than 14.3k (11.7k + 14.3k < 26,001) with a standard Class D driver's license?
What special registration requirements (and additional costs) are needed to register a privately-owned/operated 3500 SRW with a 11.7K GVWR in CA?
Thanks!
  • azdryheat wrote:
    No special license is needed if the bumper-pull trailer is less than 10,001 pounds or the 5th wheel is less than 15,001 pounds.
    Thanks.
    Old-Biscuit wrote:
    Pickup trucks are registered as 'commercial' in CA
    CA doesn't have a Class D license.....
    Class A, Class B, Class C and Class M
    Thanks for the links, Old-Biscuit. They were very helpful! So, a standard driver's license in CA is called a Class C. That's good to know.
    cmeade wrote:
    . . . Need rv endorsement on class c for 5ver gvwr between 10k and 15k. 3500 pickup not used commercially just need commercial reg and weight fee based on unladen weight. Technically a pickup has a gvwr of less than 11.5k and an unladen weight of less than 8,001 lbs. . . .
    What do you need to get an RV endorsement?
    When I used the Vehicle Registration Fee Calculator to check fees for a commercial, diesel vehicle it gives you the option to choose unladen, GVWR, or GVWR. Not surprisingly, unladen resulted in the lowest fee. I assume unladen is a valid choice for a privately owned/operated truck with a 11.7k GVWR that does not qualify as a pickup?
    Thanks again.
  • You are ok with tt less than 10k with class c. Need rv endorsement on class c for 5ver gvwr between 10k and 15k. 3500 pickup not used commercially just need commercial reg and weight fee based on unladen weight. Technically a pickup has a gvwr of less than 11.5k and an unladen weight of less than 8,001 lbs. A box type bed of less than 9 ft. 3 of 3 definitions in 575 CA vehicle code. License requirements in 12804.9 CA vehicle code. It will just get more confusing from this point on.
  • No special license is needed if the bumper-pull trailer is less than 10,001 pounds or the 5th wheel is less than 15,001 pounds.
