Tom_M1
Nov 17, 2018Explorer
theoldwizard1 wrote:Oldwizard is dead on here. Disregard all the talk about QAM, ATSC, and satellite.
Second, modern digital TV can NOT get "fuzzy" pictures UNLESS there is something between the source of the signal and the TV that is analog. Pixelation yes, fuzzy, no.
Things to check:
- Connect a known good coax cable directly from campsite post to TV set
- Make sure signal source on TV is set to 'Cable'
- Do a channel scan on TV
It's possible that a campground is distributing cable TV using channel assignments that are the same as broadcast TV. If this is the case, set signal source to antenna and do another channel scan.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
