Ron_Gratz
Apr 11, 2014Explorer
donn0128 wrote:I think that is not true for a 1-ton DRW.
IMHO towing ratings are unimportant when it comes to towing a fifth wheel.
The 2014 F-350 DRW 6.7L 4x4-174.2 has a curb weight of 8,195# and a GCWR of 30,500#.
This means that with only a 150# driver and no optional equipment or cargo, the trailer weight would be limited to 30500-8195 = 22,305#.
The 14,000# GVWR of the same TV would allow a maximum pin weight of 14000-8195 = 5805#.
The corresponding trailer weight at 20% pin weight would be 29,025#.
The 9650# rear GAWR combined with a rear Curb Weight of 3453#, would allow a pin weight of 9650-3453 = 6197#.
The corresponding trailer weight at 20% pin weight would be 30,985#.
So, "tow ratings" are important when it comes to towing a fifth wheel if the candidate TV, as in the OP's case, is a DRW.
The current crop of 1 ton SRW crew cab truck with diesel and automatic is going to scale ready to travel right around 8000 pounds.Again, the OP is talking about a DRW.
So, subtract from the GVWR 8000 pounds and generally speaking you are going to have around 2000-2500 Cargo Carrying Capacity (CCC)---
Ron
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
