outwestbound
Apr 12, 2014Explorer
JIMNLIN wrote:Ford's 2014 diesel F350, auto transmission 4x4 6.7L DRW 3.73 axle ratio......
and
RAM's comparable 2014 3500 AISIN (auto transmission) DRW 3.73 is rated to tow 23,500,
Actually your not comparing apples to apples here. The Aisin transmission uses a 1:1 direct gear ratio and requires a 4.10 axle ratio to achieve max tow ratings of 29000 lbs.
Fords Torqshift 6R140 has gear splits on both sides of 1:1 so with the 3.73 rear axle ratio operates like a 4.xxx-4.30 axle ratio (depending on transmission gear selection) to achieve max towing rating.
The Ram Body Builders Guide clicky link shows all the tow rating for each configured package truck.
Look in the notes and it mentions over 17000 lb requires a GN or 5th wheel hitch for a 3500 Ram.
If your buying a fith wheel trailer I wouldn't worry about conventional trailer (TT) weights.
Thanks, good point on the transmission differences and I didn't have that chart. I read up on the transmission gear splits and this makes good sense. I think I'll be happy with the AISIN/4.10 combination. I'm certain I'll like the 4.10 vs 3.73 in mountains. I'm curious to determine the speed that gets me the best fuel efficiency on flat interstate highways; guessing 60 MPH; kinda slow, but ok I guess with a 15,000 pound load.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
