Some cam locks on my 2001 Winnebago Itasca Spirit have rounded out their holes so the lock cylinder just spins in the hole. The previous owner just cranked the cylinder nut tighter causing the fibreg...
I have no idea what you mean by rounded out camlock holes. My camlock barrels are circular and fit into circular holes drilled through the compartment doors. Rubber gaskets/washers prevent the lock mechanisms from spinning in the holes.
If the gasket/washers are missing you can replace them or you could even use star washers which would bite into the compartment doors and prevent the locks from spinning.
Looking for advice before your next adventure? Look no further.25,208 PostsLatest Activity: Aug 27, 2026
