az99
May 15, 2013Explorer
Lynnmor wrote:X2 While you are spending that much on an open carport just do it all the way and get the pole barn. If you don't you will wish you did later. A pole barn that is unfinished inside with no living space and uninsulated should not be that much extra on property taxes. I wish I had built mine a long time ago.
I looked at them, but decided to do it right and get a pole barn. Glad I did. If you use the carport idea, you need to add a lot of extras to keep the sun and weather out. Also, they make great nesting for birds and all the "dirt" that that entails.
One advantage to the carport is the low rent (property taxes) compared to more substantial buildings.
When you go to sell your house the pole barn will be an asset. The carport will likely cost you $ to have it ripped down.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
