Blanco1's avatar
Blanco1
Camper, Trailer or motorhome?
I'm coming to realize I will need to upgrade soon enough.
& planned on a multi slide Truck Camper , but when even I drive in heavy wind this heavy truck camper up high on top of my pick up bed concerns me.
Seems like a lot of weight up high ( High Center of Gravity )
Yet have never seen even a picture of one flopped over in the wind?
I've seen in person a couple of tongue trailers & never a Motorhome?
Nor a 5th wheel.
Are the tongue trailer the most likely issue in high winds?
What about compared to a 5th wheel trailer?
I'm not crazy about buying a motorhome being the cost & I like the idea of disconnecting from a TC or Trailer & having my truck again.
& yet with any of these choices, my storage space comes into play.
I originally went went with a TC for it towing ability behind it with a car trailer or boat & etc..
Yet have learned to HATE taking my boat to the loading ramp at the water with my HEAVY TC on my trucks bed & it being a manual trans rig.
That whole parking brake & clutch & steep ramp angle game is no fun!
Yes my rig is 4X4 & 4x4 LOW does help but still.
Not in anyway pleasant.
I may just stop using this truck with the TC on it for any fishing trips.
Yet also realize most trailer sorta become an issue with the boat being involved.
Sure in Ca. I can tow a double if its a 5th wheel, but the I can't back up & its just become so long!
  • Turtle n Peeps wrote:
    What year is your truck? It should have zero launch if it's somewhere around 2003 (?) forward. (somewhere around there anyway)
    I had a 2001 5.9 HO/6 speed with the Bosch VP-44 and it also had the Zero Throttle Launch capability. The low end governor on the CP3 pumps is even better - so the ability to roll off the clutch with no throttle input was even more noticeable.
    What is Zero Launch?
    Can someone explain Zero Launch?
    My is a 1997 & I'm sure I don't have this option?
    Can I install it into my older truck?
  • The Cummins zero launch feature allows one to release the clutch with no throttle input. The computer in the truck automatically adds fuel to the engine and away you go! I can take off on steep hills with my 16k fiver with no throttle input whatsoever.
    I suspect your truck may not have this feature, but given the fact that your truck has the Cummins it will have plenty of low end torque. When pulling out of a boat launch, put the truck in 4x4 low as you indicate you have done, put the truck in first gear while holding your foot on the brake and slowly release the clutch until you feel it grab (will be noticeable by the engine starting to lug down slightly), slowly release the brake pedal and then fully release the clutch. This should allow the truck to start moving forward with absolutely no rollback at all. I have owned 3 diesel trucks with manual transmissions and I have found them all quite easy to take off with. The worst was my 6.0L Ford mostly because they have lousy low end torque.
    I have driven manual equipped trucks for so long I honestly don't even really think about what I'm doing a lot of the time; it's branded into me!
    I hope this helps. If you have any more questions fire away! :B
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
