Dick_B's avatar
Dick_B
Campground washroom needs GFCI
I am currently at a very popular campground near Columbia, MO. Their washroom has one outlet next to the sink for hair dryers, etc. As far as I can tell is it not a GFCI probably because when this CG was built such a device was either not available or required.
So the questions is should I mention this deficiency to management or let it go?
  • Ivylog wrote:
    One GFI can protect more than one outlet or it can be in the circuit breaker box...actual GFI could even be in the woman’s side. Might want to do a little more detective work before putting your foot in your mouth.
    or...simply, as in jeopardy, be sure to frame your complaint in the form of a question.
  • As noted, could very well be slaved from another GFCI. But if so it should have a GFCI Protected sticker on it.
    Could just as easily been installed before GFCI was required and grandfathered in. In that case the owner probably in no hurry to upgrade.
  • Beverley&Ken wrote:
    It is possible that it is protected by a GFCI circuit breaker, or an upstream GFCI outlet, in the 'backroom' This would keep the actual protection away from playing fingers.
    You could politely let management know of your concerns.
    Ken
    edit I was typing slowly as Ivylog was posting. sorry for duplicate response.
    It's this or the outlet is wired to a GFCI that you don't know about.
  • camperdave wrote:
    I would test the outlet before reporting it. Odds are the manager won't care anyway.
    Like fill the sink with water and toss a hair dryer in? Lol
  • It is possible that it is protected by a GFCI circuit breaker, or an upstream GFCI outlet, in the 'backroom' This would keep the actual protection away from playing fingers.
    Ken
  • I would test the outlet before reporting it. Odds are the manager won't care anyway.
  • It sure would not hurt to ask but the operator probably doesn't know.
  • Ivylog's avatar
    Ivylog
    Explorer III
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
