MetalGator's avatar
Aug 09, 2018
Can batteries cause slide issues even when on shore power?
The last couple of times we have used our dinette slide, the slide will go out about half way and then either stop or one side will stop and the other continue moving. If I then bring in the slide a little and then extend it again it will continue. It starts extending fine and then sounds like the motors are struggling. We just arrived at our site and I plugged in to power before I extended the slide. This is on a year old Class A so the batteries are only a little over a year old. I remember one time on our old TT that our fridge quit working while it was plugged in. I couldn't figure out why but then I checked the battery and it was dead. I was surprised that this happened since the TT was plugged into shore power. Once I replaced the battery the frog started cooling again. I am just wondering if when I put out the slide, the battery voltage starts dropping which could be causing my problem? I have read that Thor puts cheap batteries in their RVs. Just seems odd that this would happen with the RV plugged in to AC.
Burch
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Short answer is YES. The slides may need more power than the converter can convert.. in fact I have seen this in real life. Was ask to help move an RV from a site to storage by park management.. The house (And chassis as well) batteries were .. Well. FLAT. I mean Completely gone. We dropped in a new chassis battery (Well the Landlord bought it and I installed it) but not the house. We put 3 people on the slide. Myself and another fairly strong park employee pushing and the camp host pushing the button and got it in..
    Workhorse 8.1L vortec, been sitting for years.. Fired up and ran like it was brand new.. I drove it to storage and .. from there the former owner's family claimed it.
    Burch
    Some RV's require battery power for the slide outs , if you have a bad battery thats your problem, shore power will do you no good, other then charging your battery.
    My friend just went thru this with a fifth wheel ,bad battery , slides would not operate, even has a sticker stating such .
  • Well, are the batteries low or not? We can’t answer that online.
    Yes if batteries are low it will affect DC powered accessories. And no, plugging it in won’t instantly charge low or dead batteries.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
