DallasSteve's avatar
DallasSteve
Nomad II
Apr 23, 2023
Can I lay my surge protector on the ground?
I bought a surge protector for my electric connection. People kept telling me I need to get one so I did. My trailer has a screw on electric connection on the side of the trailer so I want to use that connection as designed which means my only other option is to connect the surge protector at the circuit breaker box. It's long so one end will be on the ground connected to the long cable. Is that a bad idea, as in getting wet when we have a big rain? I posted photos of my electric connection on the wall and the surge protector connected on the ground.
  • I'm not a dollar tree customer, but I'd think they'd have a workable plastic tote to keep your electrics out of the weather. Should be easy to custom design with a sharp knife, or box cutter.
    Jerry
  • Thanks for the replies. I edited my original post with a photo of the surge protector on the ground. Here is is again. The electrical connection is about 1 or 2 inches off the ground, but we could get a puddle deeper than that. It sounds like a unanimous vote. I should put it on a box and then a second box to cover it. I bet I can find something at Dollar Tree that I can make work with a little cutting and maybe some duct tape. The circuit breaker box on my site is pretty low to the ground. :(
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Can you lay it on the ground.. Yes but I'd not do it
    Get a box.. Something like a milk crate and lay that down. Then get another box (Solid sides and bottom( and lay that over it to shield from rain
    Rain is bad for all things electrical
    Sun for LCD displays.
  • Mine sits out rain or shine. It has a cover for the connection to the trailer. Never had any issues. It can depend a lot on what kind of surge protector you have and if it is weather/water proof. What does the manufacturer recommend?
  • Open cable ends in a puddle are more marginal and a small support can help. Use a bucket or cover of some sort for the rain.
  • Getting wet is not a great idea. I use two boxes that nest over each other.
    I place one box on the ground, then put the device to protected on top of that box. Then I nest the other box over the whole shebang to protect from the elements.
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
