wanderingaimles
Oct 31, 2018Explorer
A seven pin plug alone doesnt mean the trailer has brakes. You need a brake controller also.
As far as needing brakes, check your states rules. they do vary some but generally if your trailer is properly lit, and under a specific weight , brakes are not required.
Boats for example are frequently towed in the 3000-5000 lb range without the trailers having brakes.
If you are only looking at tail lights and have a 4 pin connector on the truck, you can use this to adapt to the trailers 7 pin, but it only provides tail and clearance lights.
https://www.walmart.com/ip/47205-4-Wire-Flat-Adapter-47515-Connector-Adapter-Hopkins-Wire-Towing-Trailer-Wiring-Wacky-Covers-Book-Weatherproof-48145-Prewired-Hopkins/636388641
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 28, 2026
