MitchF150
Oct 31, 2018Nomad
rightlaneonly wrote:
Truck has had a class four hitch installed and does have a transmission cooler.
You should also check for the additional fuses/relays for the 'tow package' as well. I think there is a 30a one for the brake controller and a relay for the 12v charge line to the trailer battery. These are found in the fuse box under the hood.
Good luck! Mitch
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 28, 2026
