time2roll
Jun 09, 2013Nomad
While in use and furnace running you should be fine at -5 but -10 might be pushing it. I would use it with water and see how it goes. And take a survey to see just what is exposed. With certain modifications you can make it work but if the water jugs are just as easy that is fine too.
You will use a bit of propane (LP) in those conditions. Check the level daily.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
