Bigmoss's avatar
Bigmoss
Can I use my fifth wheel late into the season ?
I am about to purchase my first large trailer in a few days, its a 1997 Prowler Fifth Wheel 215B 21 Foot.
I mainly use the trailer in the fall here in Canada for hunting from Sept 1 to Dec 15th or so. Of course here in Canada in Nov and Dec temps can go to -5 to -10 C. I leave the camper on a farm up against a building so it gets wind but does not get towed. I was able to get an owners manual and the unit comes with a furnace that runs on Electric and Battery I am told and I have a propane hot water tank.
My question is this I never hooked up water in my small camper I use to use but it was a 1970 and everything exposed. Being this is a more up to date unit can I hook up water to it and expect it not to freeze being the trailer is probably better insulated or should I plan on using jugs like in the past ?
Any advice for this newbie would be appreciated.
  • in your area during those times you will need a LOT of heat. even if you are hooked to power you will need a way to key the underbelly warm. DO NOT PLACE A HEATER OR LIGHT under your TT. you will have to build or install a wind break around the lower part of the TT. You will use a lot of propane during those months, you will have to winterize or freeze up.
