edb121212's avatar
edb121212
Can run propane under a carport?
We are having a house built and plan on living in the Montana on the property but I want it undercover since it will be about 6 months. I am worried about using the propane under a cover. Would this be safe? I know when you travel by ferry they want the tanks empty. Does anyone do this? The sides of the carport would be open.
  • One cup, not a gallon, one cup of gasoline equals one stick of dynamite! I have heard that if gasoline were "discovered" today it would immediately be banned for consumers, perhaps the Military would be allowed to have it! As far as natural gas/propane I think that goes back about 100 years! Most homes were heated by coal or oil fired furnaces, you had coal or wood fired stoves, and heated your hot water using the kitchen stove! Natural gas is normally colorless and orderless, so early attempts to change the way you heat your homes and water, as well as cook were met with opposition by the coal and oil providers! Laws were soon passed to put the smell in gas so you could detect a leak, but oil and coal companies spread rumors about how unsafe gas was in an effort to keep their profitable business! Fast forward we take gas in our homes for granted, but the rumors and falsehoods spread by those companies continue. "Safety" laws also lag! In the past 10 years, I have seen on TV and read about many instances where a truck delivering gasoline or heating oil has been in an accident, and a bridge or overpass had to be rebuilt because of the heat from the ensuing fire! Perhaps someone on here can correct me, but I do not recall, ever hearing about an accident involving an RV that took out a freeway because of the propane tanks it was carrying! There was a fire and explosion at a propane company in FLA, where a leaking fixture and the ignition from a trucks engine destroyed the entire yard, but no one was killed, and the ensuing fire was contained in the companies lot! In my opinion gasoline is a much bigger threat than propane!
  • OK, thanks guys, I think I probably am overthinking it. I do that a lot but safety comes first.
    They want them turned off. I never understood this, as there's usually a 40 knot wind howling constantly.
  • Coach-man wrote:
    As long as it is open, it should be ok! I have always been amazed how people fear propane and natural gas so much, but think nothing of using phones, allowing static electricity and even smoke at gas stations! How many of you stop your rig, before entering a gas station and turn off all electric devices, fridge, hot water heater, etc? Anyway, sorry for the rant, your rig under a car port with open sides will be perfectly ok!
    The gas station scenario amazes me! If people could see inside the engine's starter motor, it would scare them to death to restart their engines at a fuel island! :D
    Rusty
  • As long as it is open, it should be ok! I have always been amazed how people fear propane and natural gas so much, but think nothing of using phones, allowing static electricity and even smoke at gas stations! How many of you stop your rig, before entering a gas station and turn off all electric devices, fridge, hot water heater, etc? Anyway, sorry for the rant, your rig under a car port with open sides will be perfectly ok!
  • Not a problem, but what are you worried about? Propane is heavier than air and I'd only be concerned in a fully enclosed garage. Not necessary, but you could put 1 or 2 propane detectors under the trailer if it would make you feel better. Finally if you are building a house then you will have power, so propane use should be minimal, use electric heaters rather than the furnace. Besides electric is cheaper than propane
  • It will be fine no air will get trapped in an open air carport. I think you are over thinking it. congrats on building a home
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
