Community Alumni's avatar
Community Alumni
Jul 04, 2014
Can the weight police check these numbers for me?
I recently acquired a new TV to pull my 21' TT and I have some numbers that I would like to share with the experts here to see what they think.
The TV is a 2014 Jeep Grand Cherokee with the following specs:
6,200 lb towing capacity
6,500 lb GVWR
1,270 lb payload
4,880 lb curb weight with a full gas tank
2,540 lb front & 2340 lb rear per CAT scale
3,200 lb front & 3,700 lb rear GAWR
9,740 lb combined weight of the TV and TT, fully loaded with WDH and gas tank 1/3 full per CAT scale
2,620 lb front, 3060 lb rear & 4,060 lb TT per CAT scale
From what I gather, it seems that I'm well within the maximum limits but I'm a bit confused regarding the discrepancy between the GVWR and payload capacity based on the curb weight.
If the GVWR is 6,500 lbs and the curb weight is 4,880 lbs, logic would dictate the payload should be 1,620 lbs instead of the 1,270 factory rating. Am I missing something in the equation, or it's not unusual to have these types of discrepancies with the specs?
If you look closely, the WDH shifted 80 lbs to the front axle. Do you think that's adequate, or should I adjust the WHD to add more weight to the front or get rid of the 80 lbs. As it is right now, both the TV and TT are fairly leveled.
As always, I'm looking forward to hearing from the experts.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 28, 2025
