- Matt_ColieExplorer IIJustin,
Your big issue will be identifying if the water tap along an RV lane at a P/FJ is potable water some are and some are not. Some are there only to be used for the wash-down after a bad dump job.
Most that are not potable will have a sigh that says so. If you are in doubt, ask the people inside. If it is a freeze-Proof self draining hydrant (big hook handle), you really have to ask. You may have to find a tap on the building side, but someone should know. Many sleepers have potable tanks too.
Most MH still have both and atmospheric fill (Open thing), and a way to fill from city water. The atmospheric is usually a faster fill than is the valve from the city water connection.
Good Luck
Matt - zigzagrvExplorerI frequently fill my water tank at Flying J as well as dumping my tanks for a nominal fee. Also, some rest areas have dump stations and fresh water available, usually in the South and West.
- Will you be staying at the Flying J overnight? Or will you stay at a campground for 1 night? We would generally try to stay at at least one campground so we can FLUSH all the pink stuff really well, and fill up if need be.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
