3LittleDucks's avatar
3LittleDucks
Can you help me crunch numbers? F150, 9600 tow capacity
I'm helping a friend trailer shop, they will be towing with a F150 4x2, rated at 9600lbs. Will soon be a family of 5.
I know when we crunched the numbers for our family of 5 (with our Armada) we were surprised at how little we could safely pull, I suspect it will be the same for him.
They're looking at 25-26' trailers, dry around 4500, gvwr around 6500. Too much?
Thanks!
  • I think you would be ok with that. Just keep in mind, when they get ready to upgrade, the truck will probably need to get upgraded as well.
  • Old Days wrote:
    The reason I say that, my TC loaded weighs about 1800 pounds and when I pull my 2000 pound boat my half ton truck struggles climbing the steep hills by my house. My next truck will be a GMC 2500.
    I see. A TC is a little too much for any half-ton in my opinion. There's not enough payload capacity. My half-ton pulls my TT just fine and I travel with it in the 6200 pound range. I'v pulled some steep grades as well and kept my speed just fine.
  • pappcam wrote:
    A 6500 GVRW trailer is a good match for a half-ton unless the half-ton has no towing package or a standard V6.
    x2
  • The reason I say that, my TC loaded weighs about 1800 pounds and when I pull my 2000 pound boat my half ton truck struggles climbing the steep hills by my house. My next truck will be a GMC 2500.
  • Old Days wrote:
    I own a 2007 GMC Sierra 1500 with a 5.3 liter engine,and wouldn't even think of pulling that much weight. You need a bigger truck.
    You're kidding, right?
    Your friends need to go through a process similar to the following:
    1) Estimate how much the TT will weigh when loaded for camping.
    For example, a TT which is 4500# "dry" might have a loaded weight of 5500#.
    2) Estimate the TT's loaded tongue weight which should be around 13% of the TT's loaded weight.
    For example, a 5500# TT might have a TW of about 700#.
    When using a properly sized and properly adjusted WDH, the vertical load transferred to the TV will be equal to about 75-85% of TW, depending on how much load gets transferred to the TT's axles.
    Lets assume the TT-induced load is 550#.
    3) Look at the TIRE AND LOADING INFORMATION sticker on the driver's door edge or pillar.
    Find the maximum allowable weight for Occupants and Cargo.
    Subtract the estimated TT-induced load from the TV's max allowable payload.
    The remainder is the amount of payload capacity available for weight of occupants, items added to TV after delivery, cargo carried in/on TV, plus about 100# for the WDH.
    4) Your friends will have to decide if the remaining payload capacity is great enough to meet their needs.
    Ron
  • Actually, isn't that the answer to every question? A bigger truck?
  • I own a 2007 GMC Sierra 1500 with a 5.3 liter engine,and wouldn't even think of pulling that much weight. You need a bigger truck.
  • Depends on the f150. There are many many configurations from axle ratings to gvwrs. Need more info to make a call.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
