- Bull_RiderExplorerWe also lost an Nespresso machine due to freezing. Never gave it a thought, until the water ran out the bottom when we used it in the spring.
- dodge_guyExplorer II
Fizz wrote:
Fill it with Vodka and run it a few times. That should clear out the water.
And make for a very good morning! - FizzExplorerFill it with Vodka and run it a few times. That should clear out the water.
- Pangaea_RonExplorerIt's a bit different machine, but we ruined our Nespresso coffee maker when if froze. The reservoir that was filled with water was fine, but internally something cracked, and leaked.
- K_CharlesExplorerIt makes a difference what model it is. You hold down the brew button (as I remember) on the mini we had at work.
- 2oldmanExplorer II
wvabeer wrote:
No, I mean where in the coach?
Monongahela National forest - Dog_FolksExplorerFrom the Keurig web site FAQ:
"Once your Keurig home brewer has been primed, you cannot empty the water from the inside. The internal tank of the brewer cannot be drained. If you need to store your brewer, empty the removable water reservoir and store your brewer in a safe and frost-free environment. Please be sure to store your brewer in its upright position to avoid water leakage from the inner tank. If you store the brewer in a cold environment, you run the risk of water freezing inside the brewer and causing damage......" - wvabeerExplorerMonongahela National forest
- 2oldmanExplorer IIWhere are you carrying this thing?
- DrewEExplorer IIWhy not just empty what water you can and carry it in the cab of your truck (which I assume you keep above freezing while on the road) until you get to warmer climes?
Looking for advice before your next adventure? Look no further.25,171 PostsLatest Activity: Oct 19, 2025
