MauryFrench
Jun 05, 2013Explorer
It's the WH, and I have already done exactly what you suggested. Had all four burners going for a while. I even had flame coming out of the tube that runs right up to the pilot/thermocouple assembly. Quite a stupid move actually but funny.
rk911 wrote:MauryFrench wrote:
Have a two year old Atwood Water heater. I am not right beside it so I can't get the model number. Currently I cannot get the pilot to stay lit so the heater will obviously not continue to heat. I started removing parts and checking for blockage as best I could; gas is coming out of the main box and thru the first tube. In a 'Hold My Beer" moment I had quite the pretty flame come out of the end of the tube.
But it is not getting thru that last little connection that looks like two nuts with the actual pilot assemply on the other side. With the nuts off I can push a tie wrap thru to the end where the pilot flame would come out. But all assembled it will not put gas out of that end piece.
Any ideas? Do I order and replace that part, or could pressure be a factor? Thanks.
if, like us, this is the first time you've tried to light the fridge this season try lighting one or two of the stove burners and let them burn for a minute or so. if there is air in the line that should displace it. then try re-lighting the fridge.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
