Timsenclosed's avatar
Timsenclosed
Car handling issues
2o11 VW Golf Wagon TDI towing (w/class 3 hitch) new 5 x 10 V-nosed enclosed trailer 750lbs empty. Issue is in highway driving 50 -65 mph repetitive steering correction needed causing premature driver fatigue. Could the low quality snow tires(35lbs) be the issue? Trailer tires are 15' radial not bias ply. Planning on installing better car all season tires and a torsion bar hitch kit. Any VW drivers thoughts?
  • to help answer your questions and help solve the problem
    1) what is the ACTUAL loaded weight of the trailer
    2) What is the ACTUAL trailer tongue weight
    3) What specific tires are on the car
    4) are you using a WD hitch now? if so, who set it up.
  • The easy fast answer is the trailer probably doesn’t have enough tongue weight. The tongue weight ideally should be about 12% of the loaded on the road weight of the trailer. But the complication then becomes, how much tongue weight is your vehicle rated to handle.
