SRockwood
Oct 05, 2015Explorer II
We Cant Wait wrote:
Rather then using car hauler straps over the wheels, use a good commercial quality ratchet strap hooked to the frame of the car and the bed of the trl in an "X" pattern on both the front and rear of the car. This will stop the problem of body bounce which will effect how the trl tows behind the MH.
Unless you put some serious load on those straps, this will result in the car moving up and down from bumps in the road, making the straps go temporarily loose, then tight and back again. Eventually, one or more straps will get loose and you'll have a moving car. This is especially true for vehicles with loads of suspension travel (off-road buggies, trucks, Jeeps, etc) or stiff spring rates (racecars), as there's just no way you're gonna be able to crank down on the straps hard enough to keep it from bouncing a little down the road.
Surest way to make sure it's secure is to strap the wheels down. I usually just run a standard strap through the spokes with a couple of shop rags wrapped around the CLEAN spoke for strap and wheel protection. Make sure to feed it through the gap in the spokes NEAREST to the tie down point or you'll have problems. You can also connect the strap to the suspension on the tire side, or over the axle if it's a solid axle vehicle. Just be wary of damaging components and for your hook slipping off or up the control arm.
Once your straps are on and snug (not tight), put the trans in neutral and dis-engage the parking brake, then get all 4 straps tight before putting it back in park and re-engaging the brake.
For the over-the-tire straps, make sure your tie-down points are in line with the wheels close enough to the tire so the straps don't interfere with body-work. Out of line will pull outward on the suspension and could cause alignment problems.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 12, 2026
