Peg_Leg
May 09, 2013Explorer
On my 5er and old TT, I welded a piece of square tubing to the bottom of the frame on each side. The tubing had a 5/8" hole in the middle. These then act as dual receivers. I had a tray with an expanded metal bottom laid in a angle iron frame welded on square tubing to fit into the trailer tubes. I used 5/8" shoulder bolts with nylon lock nuts for the fasteners. I could remove it and had a ball mount to pull my 14' alum fishing boat behind both of them. Any metal fabricator shop could handle this.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
