Turtle_n_Peeps
May 08, 2020Explorer
So let me tell you about my experiences with bias tires. Ran them form the 70's up until about 2012 or so.
Never had any problems with them at all. Never. I ran all makes and models. Early I ran Goodyears but then I went to cheap China stuff. Never really found a difference for wear. I ran them hard. I usually tow 70 to 75 MPH. Weight, not so much, but I did run them fast.
I also liked them because they had nylon cords in them instead of steel belts like modern radials. The one time I did run a tire low because of a nail the tire disintegrated with no problems. If that happened with a steel belt radial it would not have ended so well.
Also, Bias tow "better" IMHO. Why? Just go to a local tire store and tell them you want to look at a bias and a radial side by side. The radial sidewall will flop around like a limp.....er... it's just weak. Now look at the bias sidewall. See the difference? Huge difference in sidewall construction.
This super stiff sidewall makes for a good towing experience as far as wind buffet goes.
So after 2012 or so I got my first set of radials. Maxis tires. They wore great and seemed to tow pretty good. No problems with them at all. They for sure wore a LOT better than the China tires I used to get. But they were also a LOT more expensive!
A few years back I got a new trailer that is heavy. I also needed new tires on it so I bought Carlisle radials for it. I have about 15K on them now and they look like brand new still. Also good tires and they tow good too but not as good as the old bias I use to run. The radials have a bit more side movement than the old radials. Not a bunch but some.
All in all they are both good tires and it just depends on what you want out of them.
Like I said, I didn't have any problems with either of them.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
