wnjj
May 06, 2019Explorer II
bid_time wrote:CaLBaR wrote:What numbers you looking at? He has 300 lbs less, which is less than 10%, everything is fine like it is.kc8suj wrote:
Here are the dry weights of truck from GMC
Curb Weight - Front 3176 lbs
Curb Weight - Rear 2098 lbs
A difference of 1,078 lbs
so I am more evenly distributed with the trailer attached. than with out. Hum?
Based on these numbers and your hooked up number your WDH is too tight. Check GM's instructions for WDH setup. After connecting you should not have anymore weight on the front than you did prior to connecting. Need to loosen up the WDH hitch a bit.
The front axle is 300 lbs more with the trailer than without. That is restoring more weight than was lost.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
