APT
May 07, 2019Explorer
kc8suj wrote:
Here are the dry weights of truck from GMC
Curb Weight - Front 3176 lbs
Curb Weight - Rear 2098 lbs
A difference of 1,078 lbs
so I am more evenly distributed with the trailer attached. than with out. Hum?
You need scaled weights of your truck, not web site/brochure weights. Your two sets of weight would suggest you have over 1500 pounds of TW on a 6000 pound trailer. I don't believe that.
There is no requirement for amount of front axle weight vs. rear weight when towing a TT, at least with respect to your measurements of front weighing 360 pounds more than rear. Unloaded I expect your front axle to weight more than rear for a pickup. Read this primer on WDH adjustment.
You should take 3 passes on on the scales.
Truck alone
Truck with trailer without WD bars
Truck with trailer with WD bars.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
