valhalla360
Jun 15, 2020Navigator
Something does look a little off:
Without the WDH:
- You have 1300lb on the hitch.
- Assuming the hitch is say 40" behind the rear axle and the wheel base is 160", you would see an additional 25% (40/160) move from the front axle to the rear. That should be around 325lb not 740lb. Now I just made up the dimensions so it will vary a bit if you use the real dimensions but I would be surprised it would be off that much.
But to the real question, the solution is really to try and move weight to the rear until yo get to around 750-800lb hitch weight. It may not be as much as you might think as weight moved from in front of the axle to behind the axle works double towards lowering the hitch weight.
Without the WDH:
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
