valhalla360
Jun 16, 2020Navigator
Boomerweps wrote:
Also not quoted above, but you need to put more tension on your WDH to push more weight to the steer and trailer axles.
If his numbers are correct, he's already pushing 500lb back to the front axle and as can be seen when he upped the tension on the WDH, it really didn't make much difference.
If he backs off the hitch weight, that should also result in more weight on the front axle without trying to over tension the WDH.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
