Andrewmart's avatar
Andrewmart
CAT Scale results - advice needed
Took my TV and TT to the scales and have some results.
TV - 2017 Expedition w/ HD Tow package
TT - 3101 BHSE (dry weight of 6100, hitch weight of 890)
Using ProPride 1400# hitch. Using 2 washers on the hitch pin.
Vehicle weights:
TV only
Steer Axle: 2840
Rear Axle: 3220
TT: 6840
TV and TT (no WDH)
Steer Axle: 2100
Rear Axle: 5260
TT Axle: 5540
Total: 12900
TV and TT (WDH 7 inches)
Steer Axle: 2600
Rear Axle: 4580
TT Axle: 5720
Total: 12900
TV and TT (WDH 7.5 inches)
Steer Axle: 2600
Rear Axle: 4560
TT Axle: 5740
Total: 12900
I entered my data on the towing planner website and got a tongue weight of 1300# and 19%. This is much higher than I thought. Any thoughts on how to bring that down?
My thoughts are to change the Propride and either adding 1 or 2 more washers into the hitch tilt pin or maybe also adjusting the height of the hitch bar. I don't have much room to increase the WD jack heights.
Any other thoughts of how to adjust weight? Maybe shift some weight in the TT from the front storage area toward the rear axles. In our trailer, the dining table is right over rear axles. I can probably fit some heavier things in that spot pretty snuggle so they wouldn't shift (e.g., ice chest, canopy, chairs, etc).
Also, note that this trip to the scale did not include about 350# of passengers. My wife and little kids were not in the car.
Thanks in advance for your thoughts and help!
    Vehicle weights:
    TV only
    Steer Axle: 2840
    Rear Axle: 3220
    TT: 6840
    TV and TT (no WDH)
    Steer Axle: 2100
    Rear Axle: 5260
    TT Axle: 5540
    Total: 12900
    Hu? How could you add over 2K in the rear axle? We need correct numbers to give you a correct answer. Are the numbers correct?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
