RCMAN46
Jul 24, 2017Explorer
Congratulations.
I have seen many posts with Cat scale numbers.
You have done the process the way it is supposed to be done.
That is three weights and it appears the correct axles were on the correct scale pads each time.
From your numbers I get a trailer weight of 6300 lbs and a tongue weight of 980 lbs which gives a tongue weight percentage of 15.5%
Assuming the trailer is level or slightly front low you should have a trailer that tows well.
As for accuracy of scale numbers CAT scales or +/- 40 lbs and if there was any significant wind during the scaling that can account for the 100 lb difference.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
