myredracer
Jul 27, 2017Explorer II
atwowheelguy wrote:myredracer wrote:
I note besides all the above posts, the remaining available payload capacity of the truck is 220 lbs with it fully loaded for camping and the TT hooked up. The effect on the tongue wt. with partial or full holding tanks will depend on the location of the tanks. If you're going to do that much, perhaps a tongue scale would help. I think 220 lbs could be eaten up quickly if not keeping an eye on things.
Look again. The case with 220 lbs. payload remaining is WITHOUT the weight distribution bars attached. With the bars attached, the remaining payload of the truck is 340 lbs. The weight distribution hitch transfers 120 lbs. from the truck to the trailer axles. Or maybe it's 140 lbs. depending on which scale is correct. Anyway, the truck is 120 lbs. lighter and the trailer is 140 lbs. heavier with the WDH bars attached.
But yes, a couple more passengers on board would put it at the limit.
You are correct. I had thought about that and was going to include it but a day later forgot all about it. Not a good sign. :(
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
