gbopp
May 04, 2017Explorer
westend wrote:
You need to go back to Plumbing 1-01. There should be no reason to expect a leak.
x2. I've used SharkBites on the heating system in my house for over 10 years. No problems.
As mentioned, there are cheaper alternatives to SharkBites.
As long as you're building the plumbing system, why not use Pex and run all the joints to one central location, like in a storage bay?
Personally, I wouldn't be concerned about leaks. If you do it right it won't leak. And if it does, it may be the result of something you couldn't control.
Do you worry about possible leaks at your S&B when you are in the RV?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
