wa8yxm
May 04, 2017Explorer III
How does that song go...
When the shark bites. Into pex dear, Plumbing leaks Go away
When the Shark Bites Into pex dear, Dry times are hear to stay.
The only "Catchment" system I know of is a larger pipel. FOr example you can put a 2" pVC over the 1/2 inch PEX and if it leaks, the PVC is drained to under the RV.. IN fact that is how some pipelines are built and all should be
With a pipe inside a pipe (inside a pipe) so if one bursts, the next size up plays Catch.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
