Svenn
May 04, 2017Explorer
wa8yxm wrote:
The only "Catchment" system I know of is a larger pipel. FOr example you can put a 2" pVC over the 1/2 inch PEX and if it leaks, the PVC is drained to under the RV.. IN fact that is how some pipelines are built and all should be
With a pipe inside a pipe (inside a pipe) so if one bursts, the next size up plays Catch.
That's a good idea, though the pipe would have to be clear so I could see if there's a leak or not? Also, for example the horizontal output pipe at the bottom of the water tank would need a bigger pipe around it that would also seal up to the tank, otherwise a leak there could spray out everywhere.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
