2012 Crossroads Cruiser 5th wheel. The ceiling lights are I guess you'd call them pot lights. The covers are almost flat and they don't turn. How in heck do you get these things off ?
They don't slide or turn and there is nowhere to grip on to turn as the lenses are almost flat & flush with the mounting pod. I've tried a slot screwdriver but there isn't room to slide it in around the edges.
Many of the covers are pushed on and pulled off. Of course, if you pull real hard and a cover breaks, then it must have a different method than I indicated. Some have springs or clips that hold it up. Once you pull out the trim a bit, you may see the clips - to be depressed.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
