- Horizon170Explorer
ventrman wrote:
Horizon170 wrote:
Not sure whether you have a travel machine or not but if the power requirement isn't too great you could run it off a couple of batteries and an Inverter maybe.
You would need a ventilated cover for a generator probably. I have a Honda 2K and wouldn't run it in the rain. I have provisions for a waterproof cover for mine but doubt anyone else has a setup like mine.
For a make shift cover I would chain my generator to the front bumper and close the hood on a tarp and run the tarp at a 45* angle to the ground and use tent nails to secure it in an emergency.
Mine does not have a Battery. It is strictly AC.
Can you provide Pictures of your Setup?
Here is a pic of my Generator tray and I have a 2K Honda affixed to the passenger side with all 4 feet anchored plus an aluminum box cover with two locks and chain when the gen is running with the box stored on the rear. I also have a transfer switch inside and a 30 amp cord run to the front permanently.
I do not however run the Gen while sleeping even though I have a propane and a CO detector in the RV. If it is raining I close the hood on a tarp and run the other end at 45* and anchor with tent pegs.">Clicky
- Turbo_Diesel_DuExplorerI ran my old C-Pap machine off a 12 volt with a converter fort 84 hours straight.
- ventrmanExplorerThanks for all of the Input. I am still deciding what I am going to do, I have a 35000/4000. It will not be used in a Campground.
Is it Possible to route the Exhaust through a Hole in the big Compartmenet under the front of my my 5th Wheel with a Pipe of some sort to vent Exhaust Gasses away from the Trailer and run it inside that Compartment with the Door open so it gets enough Air Flow? I can fix the Door at an Angle so the Rain would not be an Issue, and still allow for adequate Air Flow. - JiminDenverExplorer IIWhich Champion generator are you talking about. A 2000i inverter cube would idle along at 53 db. My 3500/4000 on the other hand would wake the dead at 67 db. I have run it in the rain with a piece of carpet draped over it.
- RGar974417ExplorerYou could use a large dog crate.
- wbwoodExplorerGet an ez up tent and put the genny underneath it away from your camper. You can lower the tent down to a few feet for maximum coverage.
- bikendanExploreri don't know of any campgrounds that allow generators running during the night.
- buzzard616ExplorerI use a 300 W inverter. I have run the C pap for four nights before requiring a recharge.
You could also use one of those 'booster packs' to plug the inverter into.
Some of the fancier ones have the inverter built in.
You can use it for a day or so and then find somewhere to charge it.
Stu - dtappy3353ExplorerI use a CPAP and have the following set up:
1. purchased a marine deep cycle battery of 100w minimum.
2. obtained 12 volt harness for my cpap from manufacturer.
3. purchased a digital battery charger for shore power recharging after cpap use.
4. when battery is approx. 100% charged, I can get 3-4 cpap uses out of it before having to recharge.
5. it would unusual to use a cpap more than 6-8 hrs at a time.
6. rv generator will also charge battery if no shore power is available within 4-5 days.
Hope this helps.
Best of luck. - TerryallanExplorer II
naturist wrote:
I think I'd be working on ways to run the C-Pap off batteries. A Champion generator running all night is a prescription for poor sleep for yourself and a lot of animosity from anybody within a mile or so. Those things are noisy, especially in the silence of darkness.
I didn't think C-Paps drew enough power to require a genny.
According to this: http://www.apneaboard.com/forums/Thread-Equipment-How-many-DC-Amps-does-my-CPAP-REALLY-draw you should have no reason to run a generator. 5 amps at 12 volts is only 60 watts, and running even the smallest generator, a 900 or 1,000 watt unit, would be overkill. If you have one of the 1 to 2 amp C-Pap machines, it'd be like hookin' up a nuclear air craft carrier to tow your canoe.
Not to mention. "MOST" primitive campgrounds do NOT allow generators to be ran at night, during quiet hours.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
