j-d wrote:
Those with Hondas are supposed to start the engine and go through the gears every so often, right? Does the charge line have to be disconnected? I can see where if one battery was low, the charge line would try to act as a jumper cable and get really hot.
j-d,
Well Sir, yes the Honda manual, if I recall, mentioned something about only towing for around maybe 6-8 hours or so and then a break was needed to start it up and run it through some gears. I can't remember and someone that's still towing one I'm sure will verify or correct me on that.
Now, as for your assumption of the "charge line" acting as a jumper, well, if it's doing it's job correctly, as in charging the CRV battery, then the Honda starts in about 1-2 seconds, each and every time so, the potential for that charge line getting over heated because it's still connected to the coach, I think is nil. Besides, I (along with most folks) installed a fuse in it so, there's a built in safety factor there too.
Scott
