There has been a lot of discussion on charge lines being added to supply 12v to the toad. What is a reasonable cost for materials and installation by a dealer? I assume the ideal time to add a charg...
JL7456, If you are starting from scratch and buying everything new, you would buy the 6 wire umbilical instead of a 4 wire. As far as running the Charge Line goes. On my RV it was already at the back of the RV, so all I had to do was run the wire from the Toad Plug to the battery through an in-line fuse. Took maybe 5 minutes more effort.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
