Matt_Colie
May 16, 2013Explorer II
If you put 12V batteries in parallel, you will be hard pressed to get capacity X2 from them. Lead acid batteries just do not play well together. If the two are not of the same line the same day. They will never both come to full density (charge) at the same time. And, if they are different ages - just forget it....
If you are stuck with it that way, separate the batteries for charging, but the weaker battery will still drag the better down while they are connected.
This is true of all banks of paralleled LA batteries.
IF this is just for a season, do what ever, but if you are going to replace either or both then go get a pair of golfcart batteries and put them in series for 12V.
I made a living do DC electric on expensive boats for many years.
Matt
Matt
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
