wa8yxm
Aug 02, 2013Explorer III
You said: You have 2 six volt batteries in series.
I saw: You have one big 12 volt battery
Simply ignore the jumper that connects the two of them DO NOT connect anything to that wire or to the terminals on the ends of it. Use the most negative (That runs off to chassis ground) and the most positive (That runs off to who knows where (your fuse block) and you are looking at a 12 volt battery.
Treat them as though they were one 12 volt battery for all purposes save removal and replacement, You can do that half a battery at a time.
Now, that 12 volt battery charge outlet on your honda.. FORGET IT. it's junk you are much better off feeding say a Progressive Dynamics 9260 with the 120 volt outlet on that honda. Faster and better charging. Or the converter in your trailer if it's a good 3-stage. (Such as the one I named) note there are MANY just as good.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
