- Grit_dogNavigator
Turtle n Peeps wrote:
I went to 2 campgrounds on vacay and both had in their rules: "If you have an electric vehicle, do not charge at your campsite. There is a charging station down the road for this purpose."
I have an idea you will see more of this. There is no way most campgrounds can support this kind of energy.
Noooo, you're looking at it the wrong way....
Youuuu need to get 10 grand worth of batteries and solar panels and inverters so that YOU aren't a burden on the electrical service so that those who have EVs have enough power to charge them!
Something funny I just thought of... buy all that chit I mentioned above, so you can go be one with nature and eco friendly and not have the smell and noise of a generator....but you can't tow your eco friendly RV with an EV because you don't have a generator to charge it. So you end up camping next to a plug in for your car whilst harvesting the golden rays of the sun to not use the power to plug in your camper! pianotuna wrote:
The results were expected if they had done some homework.
Hi all,
Some interesting results.
https://youtu.be/Xnyc6oNsB_w
Amateurstime2roll wrote:
Hi all,
Amateurs
Yah a rookie mistake for sure but its part of the learning process.
We carry a campground charging kit with 4 dongles for the EVSE that came with the car.
5-15 which allows charging at 12 amps at 120 volts
5-20 which allows charging at 16 amps at 120 volts
TT30 which allows charging at 24 amps at 120 volts
14-50 which allows charging at 32 amps at 240 volts
But these are "intelligent" dongles with a little circuit that tells the EVSE the max it can draw from any given circuit. This prevents breaker tripping.
In addition it has a temperature sensor in the plug in end. If it detects high temperature caused by a bad connection on the receptacle it will limit the current to either 75 percent or 50 percent or shut it right off. It also does this if it detects low supply voltage. Nice.
By far our most used dongle is the TT30 as we rarely rent 50 amp sites.
Here is our kit. The EVSE and 5-15 came with the car, we bought the other three dongles. There are 9 available in all so you can pretty much plug into anything, welders, dryer outlets etc, but these are the only ones we use.
We are using the TT30 at this site.- midnightsadieExplorer III won,t ever have this problem.
- NamMedevac_70Explorer IISounds like electrical overload. Campground pedestals are no EV charge stations. I won't ever have this problem. Cheers to my common sense
- 3_tonsExplorer III
Same here…Not to knock the impressive engineering of EV’s (free enterprise addressing the marketplace), but my sense is that we’re nearing a grid juncture where gov authorities can and will turn on and off the charging (meaning vehicle mobility) as may be deemed appropriate…Without a renewed enhancement of the grid, the future of transportation is becoming a bit less certain - JMHO only…
3 tons - PButler96Explorer
shelbyfv wrote:
Yes, seems a number of state parks are providing dedicated charging stations. Linky More will surely follow. I think KOAs are also beginning to offer this.
I've seen them in PA and WV state parks. The ones I've seen are not anywhere near the campgrounds. At Blackwater Falls WV they are at the lodge 2 miles or so away from the campground. I guess if you have the time to go to them and wait around while charging they're great. Not a lot to do at the Blackwater Falls lodge though. Hike a trail or have an overpriced dinner that is basically low grade dog food. Frozen entrees and veggies from a can. - LatnerNomad
X2 - shelbyfvExplorerBummer about the WV park food. Here in TN the parks usually have good restaurants. I love a buffet!
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
